BookmarkSubscribeRSS Feed
msnthrop
Community Member
Jul 23, 2012
text control in biplot graphs
JMP 9 - Mac
I've been trying to format a biplot that was produced from a PCA run based on soil physical/chemical properties.  A few of the values end up right on top of each other in the biplot graph and I've been unsuccessful in figuring out how to either alter the text size or spread so I can see each ray point ending clearly.  Is there a way to control the text in the graph...or alternatively to alter the axis minor tick spread so as to give the points more room to spread out and be seen?  Thanks!
