hacketkm
tabulate: adding analysis columns using values from a list of strings
I have a list of strings which represent column name. I want to Tabulate a data table using this list as the Analysis Columns.
My script resembles:
abc = { "A", "B", "C", "D" };
Tab = dt << Tabulate(
     Show Control Panel( 0),
     Add Table(
          Column Table( Analysis Columns( abc)))
There is a problem when JMP runs the Analysis Columns. Does anyone know how I could make this work?
pmroz
Re: tabulate: adding analysis columns using values from a list of strings
Use EVAL LIST.
abc = {"A", "B", "C", "D"};
dt = Current Data Table();
      Show Control Panel( 0 ),
      Add Table( Column Table( Analysis Columns( Eval List( abc ) ) ) )
pmroz
Use EVAL LIST.
hacketkm
That was an easy fix!
Thank you very much
