dingo
summary analysis on repeated data
Hi everyone,
I need to get the number of rows of  reaped sequence of grouped data e.g. a column data of the form:
aaabbbbbccaaadddbbb...
Using Summary Statistics option and grouping by this column will result in total number of occurrences for each value of abcd (N Rows): 6,8,2,3. what I need is the number of rows for each group separately in sequence:
a,b,c,a,b,d (N Rows): 3,4,2,3,3,3
any idea?
Thanks,
 - Dean
Re: summary analysis on repeated data
My suggestion is that you create a new formula column using the following formula:
If( Row() == 1, counter = 0 );
If( Lag( :yourgrouppedcolumnname ) != :yourgrouppedcolumnname,
	counter++,
	counter
counter;
Replacing "yourgrouppedcolumnnmae" with the actual column name that has the repeating columns.
Then you can run the Summary Platform
     Tables==>Summary
on the new column, and it will give you the counts for each of the groupings.
If you need the results back into the original table, you can simply use the Update Platform on the original data table, pointing to the Summary table, and matching on the new column you created.
Below is a sample script using the Big Class sample data table.
// Create the new binning column based upon the "Sex" column
dt << New Column( "Bin",
	formula(
		If( Lag( :Sex ) != :Sex,
			counter++,
			counter
		counter;
// Calculate the counts of the new binning column
dtSummary = dt << Summary(
	Group( :Bin ),
	Freq( "None" ),
	Weight( "None" ),
	Link to original data table( 0 )
// Move the counts into the original data table
dt << Update( With( dtSummary ), Match Columns( :Bin = :Bin ) );
dingo
Thanks Jim,
I'll try it.
Best,
 - Dean
