sum transactional data
Alexllorens
Occasional Contributor
Oct 3, 2017
Hello, I'm trying to SUM the Quantity variable PER customerID. This is transactional data (sample below)
How to get that sum for each single customer when I have over 500K rows with 4K customers?
QuantitydummyInvoiceDateTotal PurchaseUnitPriceCustomerIDCountrydays since
111-Dec-1110-Dec-11505014911EIRE1
1211-Dec-1110-Dec-1117.41.4514911EIRE1
311-Dec-1110-Dec-1129.859.9514911EIRE1
1811-Dec-1110-Dec-1167.53.7514911EIRE1
411-Dec-1110-Dec-11174.2514911EIRE1
311-Dec-1110-Dec-1114.854.9514911EIRE1
611-Dec-1110-Dec-1117.72.9514911EIRE1
1211-Dec-1110-Dec-1110.20.8517489United Kingdom1
1211-Dec-1110-Dec-11151.2517489United Kingdom1
1211-Dec-1110-Dec-1119.81.6517489United Kingdom1
1211-Dec-1110-Dec-1124.962.0817489United Kingdom1
1211-Dec-1110-Dec-119.960.8317489United Kingdom1
Jun 22, 2012
Solution
You can either use
     Tables==>Summary
To create a new data table with your sum calculated per Customer ID
or
You can use
     Analyze==>Tablulate
To create a report of the sum for each Customer ID
or
You can create a new column in your data table and use the following formula to generate the sum for each customer ID
Col Sum(:Quantity, :Customer ID)
Jun 22, 2012
Solution
You can either use
     Tables==>Summary
or
You can use
     Analyze==>Tablulate
or
Alexllorens
Oct 3, 2017
Thank you very much!
