BookmarkSubscribeRSS Feed
konstantin
Mar 21, 2014
stepwise regression next term selection method?
Hello!
Can someone tell me what is selection method JMP uses when Max R2 KFold or Minimum BIC or AICc stopping rules are selected during stepwise regression? it is not really clear if stopping rule is also a selection method if the stopping rule is not p-value selection threshold. When I select  ether  Max R2 KFold or Minimum BIC or AICc stopping rule, JMP comes with the same sequence of new cross terms, the only difference is as when it stops to select new cross-terms.
Thanks!
