jemg
solved
solved
MGO
ih
Super User (Alumni) ih
Re: How to save the script IF the report was generated from new windows ???
Instead of opening the reports in the new window, could you just load the platforms directly?  Using this method you should have the entire platform available:
Names default to here(1);
dt = Open( "$Sample_data/big class.jmp" );
New Window("Reports",
	H List Box(
		Bivariate( Y( :height ), X( :weight ) ),
		Oneway( Y( :height ), X( :age ) )
jemg
solved
MGO
ih
I don't know of a straight forward way to take an existing report and save the script from it without a couple steps in between.  But you can build the new window with a for loop:
dt = Open( "$Sample_data/iris.jmp" );
New Window("Reports", hlb = H List Box( ) );
cols ={:Sepal width, :Petal length, :Petal width};
for(c=1, c<=n items(cols), c++,
	hlb << Append( Bivariate( Y( cols[c] ), X( :Sepal length ) ) )
jemg
solved
MGO
See Line Up Box display box.
