bthaby1
sheetbox in a for loop ?
I have been trying to create a display using sheet boxes and its not going well.
I am using a for loop to create a display and using "hsheetbooxname << append" commands . .
but not getting it right.   In this simple example below. . can someone
show me how to convert this to type where you open an empty sheet box. .
then append in the different objects ?    The << Hold command has me stumped.
dt = Open("$ENGLISH_SAMPLE_DATA/Big Class.jmp");
dt << minimize window();
NewWindow("Example",
  VSheetBox(
  <<Hold(Bivariate(Y(:weight), X(:height), FitLine())),
  <<Hold(Distribution(Continuous Distribution(Column(:height),Horizontal Layout(1),Outlier Box Plot(0)))),
  <<Hold(Tree Map(Categories(:age))),
     <<Hold(Bubble Plot(X(:height),Y(:weight),Sizes(:age),Coloring(:sex),Circle Size(6.226),All Labels(0))),
  HSheetBox(
  SheetPart("", ExcerptBox(1, {PictureBox(1)})),
  SheetPart("", ExcerptBox(2, {PictureBox(1)}))
  HSheetBox(
  SheetPart("", ExcerptBox(3, {PictureBox(1)})),
  SheetPart("", ExcerptBox(4, {PictureBox(1)}))
ms
Super User ms
Re: sheetbox in a for loop ?
Almost there. It seems like Hold() works with the expression rather than the platform object.
Try redefining your g's like this:
  g1 = expr( Bivariate(Y(:weight), X(:height), FitLine()));
  g2 = expr( Distribution(Column(:height),Horizontal Layout(1),Outlier Box Plot(0)));
  g3 = expr( Tree Map(Categories(:age)));
  g4 = expr( Bubble Plot(X(:height),Y(:weight),Sizes(:age),Coloring(:sex),Circle Size(6.226),All Labels(0)));
8 REPLIES 8
bthaby1
Here is more of the format I am looking for. . this one does not work.
I need to apply the logic to a much larger sheetbox project I am working on.
w = NewWindow("New Example", vsb = Vsheetbox());
  g1 = dt << Bivariate(Y(:weight), X(:height), FitLine());
  g2 = dt << Distribution(Column(:height),Horizontal Layout(1),Outlier Box Plot(0));
  g3 = dt << Tree Map(Categories(:age));
  g4 = dt << Bubble Plot(X(:height),Y(:weight),Sizes(:age),Coloring(:sex),Circle Size(6.226),All Labels(0));
    vsb <<Hold(g1);
    vsb <<Hold(g2);
    vsb <<Hold(g3);
    vsb <<Hold(g4);
  sp1 = SheetPart("platform1", ExcerptBox(1, {PictureBox(1)}));
  sp2 = SheetPart("platform2", ExcerptBox(2, {PictureBox(1)}));
  hsb1 = HSheetBox();
      hsb1 << append(sp1);
      hsb1 << append(sp2);
    vsb << append(hsb1);
   sp3 = SheetPart("platform3", ExcerptBox(3, {PictureBox(1)}));
  sp4 = SheetPart("platform4", ExcerptBox(4, {PictureBox(1)}));
  hsb2 = HSheetBox();
   hsb2 << append(sp3);
   hsb2 << append(sp4);
  vsb << append(hsb2);
    w << Bring Window to Front;
  w << refresh;
ms
Super User ms
bthaby1
Thanks MS.. that worked perfectly and saved me more frustration with that hurdle.
My bigger project actually has some Substitution expressions using a list of columns. .will see if I can apply this learning to that.
Will let you know how it comes out.  I may be calling again.
ms
Super User ms
I tried to build a sheet box with a for loop and came up with this code. It's adapted to collect graphs from a report with an arbitrary (>1) number of by-groups, i.e several similar graphs for different subgroups within the same window. But the principle should be possible to adapt to any collection of objects. Btw, try changing Picture Box(1) to Table Box(1) or Listbox(1).
// Script to collect graphs from a report with by-groups
dt = Open( "$ENGLISH_SAMPLE_DATA/Big Class.jmp" );
by_column = Column( "age" );
objexpr = Expr( Bivariate( Y( :weight ), X( :height ), FitLine(), by( by_column ) ) );
//some math to define the layout
Summarize( g = by( by_column ) );
nobj = N Items( g );
rows = Floor( Sqrt( nobj ) );
cols = Ceiling( nobj / rows );
//Set up the panels
vsb = V Sheet Box( <<hold( objexpr ) );
HSheetBoxes = {};
For( i = 1, i <= rows, i++,
  Insert Into( HSheetBoxes, H Sheet Box() );
  vsb << append( HSheetBoxes[i] );
// Populate with elements from reports
For( i = 1, i <= rows * cols, i++,
  If( i <= nobj,
  HSheetBoxes[Ceiling( i / cols )] << append(
  Sheet Part( by_column << get name || " = " || g[i], Excerpt Box( i, {picture Box( 1 )} ) )
  HSheetBoxes[Ceiling( i / cols )] << append( Spacer Box() )
//Make window
New Window( headname(objexpr), vsb );
bthaby1
Wow.  Your for loop example is great and close to what I am trying to do.   Yours is much more elegant than mine.  Humbling.  I will have to study yours
carefully.   My brain is still scripting basic expressions and evaluating basic expressions. . I need to get this concept to click to get to the next level.
Thank you.
ms
Super User ms
Thanks! The conditional spacer box thing is just cometic. It adds empty boxes to the end if the number of graphs does not fit the layout matrix. It works without this feature but any trailing graphs are then automatically resized to fill the sheetbox which may look ugly.
For me, learning JSL has been a lot of trial and error. Many hours spent to find elaborate workarounds for (poorly documented) things that "should" work but don't. Later I often find a much simpler way, e.g. on this forum. Good luck!
bthaby1
MS,
in your sheetbox example above, can you save this as a journal ?
I get a jmp exception when I do.
Brad
ms
Super User ms
If you mean to Journal the Window holding the sheetbox, yes, I can save it to a journal both manually and by script. The displaybox vsb can also be journaled directly. Tested with JMP 9 and 10 for Mac.
