statganda
setting of bin & label
Hi JMPers,
Is there a script for setting the minimum, maximum boundaries and bin in multiple histogram? Also how to change the label in the Y - axis?
Thanks a lot,
ms
Super User ms
Re: setting of bin & label
Here is an extension of the sample script posted in your previous thread (about adding reference lines). The script uses the same approach to set max, min and bin width of the histogram. It also adds Y-axis labels, in the example simply the by-group names.
