BookmarkSubscribeRSS Feed
alex
Community Trekker
Jun 23, 2011
select isn't selecting the right items
I have number of iterations of the below....where each one uses a different X & Y column. In 2 of these iterations the results are totally wrong and JMP selects a subset that is obviously wrong (lots of X < 40 and lots of Y that equal 1)
Any ideas?
//select X to get a list of items for this phase that need escalation
dt <<Clear Select;
dt <<Select Where( :X > 40 & :Y==0 );
dt <lt;Subset(output table name("X subset"));
edit to make code example show up
Message was edited by: alex
ms
Jun 23, 2011
Re: select isn't selecting the right items
Maybe the row selection is not always able to match the iteration rate, i.e. the subset is created before the row selection is finished.
Try to insert a Wait(0.5) command in each iteration (experiment with different arguments, sometimes Wait(0) is sufficient).
Message was edited by: MS
alex
Community Trekker
Jun 23, 2011
It turns out that the above happens where NONE of the lines in the set match the criteria.
So, instead of getting the subset of everything that matches X & Y, because nothing matches X & Y, JMP actually grabs a much bigger subset...(but not the whole set)
Seems very odd.
Any further suggestions?
alex
Community Trekker
Jun 23, 2011
turns out that this is addressed in question 5.6 of Jumping into Jmp
Question 5.6:
I am attempting to select some rows, and then create a subset data table. When no rows are selected, all the rows are included in the subset data table. How can I create a subset only if there were rows selected?
Solution 5.6:
Get the number of rows selected using the Get Selected Rows command, and then verify the result is greater than 0 before creating the subset as shown in the following code:
/* Select the desired rows. */
dt << Select Where( :age == 54 & :sex == "F" );
/* Store the number of selected rows in a global variable. */
selRows = N Row( dt << Get Selected Rows );
/* Perform a subset if rows were selected. Otherwise, print
a message in the log. */
If( selRows > 0,
dt << Subset( Output Table Name( "Age 54 Females" ) ),
Print("No rows selected.")
anneg
Community Trekker
Jun 23, 2011
I had the same poblem (but I had the book :-) and now a further one, because I wanted generate a graph using the subset data table, but now I don't have a subset data table.
1. question: can I then create a subset data table with no rows in it - or with a dummy row?
2. question: Is there a easy possibility to check if the subset data exist and then create the graph (more complicated because i generate more than 1 graph with this Subset data table).
pmroz
Jun 23, 2011
I take a different approach. Instead of creating a subset each time I want to plot a different search, I simply exclude data that didn't meet the search criteria. Next I create a plot from the original dataset
dt << select where(:A > 40 & :B == 0) << invert row selection << exclude << clear select;
Hi man, I think tat you should use CART algorithm which is very fun !
