Kevin
select day and input text
I tried to  write "test" on Status column when date is 26. so I first get day from time column and write the follow script, but it doesn't work. Can someone take a look what's wrong with my script
TimedateStatus
06/26/2018 1:46:50 PM26
06/27/2018 2:30:09 PM27
06/28/2018 4:13:20 PM28
sdt=current data table();
sdt << selectwhere (:date ==day(26) );
selRows = sdt << getselectedRows;
Ascolumn (sdt, "Status")[selRows]="test";
Re: select day and input text
You are taking the Day() function of 26, and what you want to do is to take the Day() function of the :Date column.
sdt = Current Data Table();
sdt << selectwhere( Day( :date ) == 26 );
As Column( sdt, "Status" )[selRows] = "test";
Kevin
Thank you, it works! Another question, if I would like to set 26 as vaiable,
x1=26
sdt << selectwhere (Day(:date) == x1 );
As column (sdt, "Status")[selRows]="tested";
Does this look right?
What you show will work....with one slight change.....you need a ";" after X1 = 26
X1 = 26;
