ENTHU
searching for a folder.
I have a code to accept folder name as input .Now I want to check if the folder exists in one of the 2 paths (pathA and PathB).
I was also able to achieve this but the challenge is,
I have many folders in these 2 paths and I dont know the name of these before-hand.
I tried using
filelist=Files In Directory( path1, recursive);
but this doesnt work for folders.
pauldeen
Re: searching for a folder.
Will this help you?
If( Directory Exists( "$SAMPLE_DATA/Loss Function Templates" ),
	"ok",
	"missing!"
Your code example uses the wrong syntax. Here is an example of the correct syntax:
Files In Directory( "$SAMPLE_DATA", Recursive( 1 ) );
The items in the list that is returned are full paths, so you can examine each one to find the target folders.
Craige_Hales
Staff (Retired)
descend = Function( {path},
	{candidates, i},
	If( !Ends With( path, "/" ) & !Ends With( path, "\" ),
		path = path || "/"
	candidates = Files In Directory( path ); // not recursive
	For( i = 1, i <= N Items( candidates ), i += 1,
		If( Is Directory( path || candidates[i] ),
			Write( "\!n", path || candidates[i] ); // <<<<<< do something
			descend( path || candidates[i] ); // optionally, recurse
descend( "c:\program files" );
If you don't want to explore sub directories, comment out the recursive line.
Craige
