BookmarkSubscribeRSS Feed
scripting bug in JMP13
robust1972
Jan 15, 2014
I am transitioning my scripts to JMP13.0 from JMP12.2. I found a scripting bug in JMP13. the details are explained with a sample script.
dtfemale = dt << select where( Contains( :sex, "F" ) ) << subset( Output Table Name( "femal students" ) )<<delete rows;
in jmp12 dtfemale is the subset of Big Class(female students), whereas in JMP13.0 dtfemale became becomes a row number(18); Is this something could be solved by setting in preference? or was it fixed in 13.1? I have at least few tens lines in my script, it is quite a big inconvenience to change it line by line. Any thoughts and suggests will be appreciated!
Justin_Chilton
Aug 27, 2015
Solution
In JMP 13, the 'Delete Rows' message now returns the total number of rows that were deleted. It is probably best to separate these messages into different lines and avoid doing to many messages on a single line.
dt << select where( Contains( :sex, "F" ) ) ;
dtfemale = dt << subset( Output Table Name( "female students" ) );
dt << delete rows;
Edit: I wanted to add that since delete rows didn't return anything previously, the return of the subset message was set to the variable. This is because the last message on a single line that returns something is returned to the variable on that line.
Justin
1 REPLY
Justin_Chilton
Aug 27, 2015
Solution
dt << delete rows;
Justin
