BookmarkSubscribeRSS Feed
JimPappas
Nov 2, 2016
script to automatically change Y-variable on graph to a different variable
Hello.  I would like to be able to send my graph (a simple scatterplot made in graph builder) a scripted message that would automatically change the current Y-variable to a different variable.   I don't really want to redo the graph because of several "bells and whistles" that are already part of the script.   I know that column switcher is a great way to present a dialog box of options to the user, but really just want it done automatically in  a single step.   Any advice is appreciated... Thanks, Jim
Jun 22, 2012
Solution
Re: script to automatically change Y-variable on graph to a different variable
Here is an example of how to do this with a Graph Builder Scatterplot:
dt = Open( "$SAMPLE_DATA\big class.jmp" );
gb = Graph Builder(
	Size( 587, 495 ),
	Variables( X( :age ), Y( :height ) ),
	Elements( Points( X, Y, Legend( 6 ) ) )
Wait( 4 );
ColumnSwitcherObject = gb << Column Switcher( :height, {:weight} );
ColumnSwitcherObject << Next;
ColumnSwitcherObject << run;
ColumnSwitcherObject << remove column switcher;
Jun 22, 2012
Solution
gb = Graph Builder(
	Size( 587, 495 ),
Wait( 4 );
JimPappas
Nov 2, 2016
Thank you so very much!  That worked and saved me a ton of time (assumming I could have ever figured that out).  Happy holidays....
