Sebnem
script/formula _add a comment in a new column after a certain date
I have a table (attached) and created column "condition". I want this column to say "before" or "after"  based on the date stated in
varProcessChange. I can't make it work correctly. Can you pleas see what Is missing?
varProcessChange = Date MDY( 09, 1, 2020 );
Eval(
Eval Expr(
colCondition = dt1 << New Column( “Condition”,
character,
nominal,
formula( If( :name( "MonthYear" ) < Expr( varProcessChange ), "Before", "After" ) )
thank you
Re: script/formula _add a comment in a new column after a certain date
I think this is the best way to handle your issue
dt1=current data table();
Eval(
	Substitute(
			Expr(
					character,
					nominal,
					formula(
						If( :name( "MonthYear" ) < __vpc__,
							"Before",
							"After"
		Expr( __vpc__ ), varProcessChange
Eval(
	Substitute(
			Expr(
					character,
					nominal,
					formula(
							"Before",
							"After"
