chang
script for specifying DBQ
I am wondering how I could specify the source of the database so this, perhaps as a global statement, could be referred by each dt=. As you could see in the the following script, to get data from multiple Access tables I duplicate DBQ=.... for each dt=. The only difference is the "SELECT..." part. In SAS, I would write a macro variable (%let dir=E:\Now\(Project) RFID_r3_Homing_r1\Ben analysis\) to specify the location of the database. But I haven't learned how to do the similar in JMP. I have underlined the duplicated part of the first two dt=. My script is attached.
dt1=Open Database( "DBQ=E:\Now\(Project) RFID_r3_Homing_r1\Ben analysis\Chang_bee_db.mdb;DefaultDir=E:\Now\(Project) RFID_r3_Homing_r1\Ben analysis;Driver={Microsoft Access Driver (*.mdb)};DriverId=25;FIL=MS Access;FILEDSN=C:\Program Files\Common Files\ODBC\Data Sources\chang_bee_db.dsn;MaxBufferSize=2048;MaxScanRows=8;PageTimeout=5;SafeTransactions=0;Threads=3;UID=admin;UserCommitSync=Yes;",
    "SELECT * FROM qryAFF14",    "qryAFF14", invisible);
dt2=open database( "DBQ=E:\Now\(Project) RFID_r3_Homing_r1\Ben analysis\Chang_bee_db.mdb;DefaultDir=E:\Now\(Project) RFID_r3_Homing_r1\Ben analysis;Driver={Microsoft Access Driver (*.mdb)};DriverId=25;FIL=MS Access;FILEDSN=C:\Program Files\Common Files\ODBC\Data Sources\chang_bee_db.dsn;MaxBufferSize=2048;MaxScanRows=8;PageTimeout=5;SafeTransactions=0;Threads=3;UID=admin;UserCommitSync=Yes;",
    "SELECT * FROM qryALF0", "qryALF0", invisible);
dt3=Open Database( "DBQ=E:\Now\(Project) RFID_r3_Homing_r1\Ben analysis\Chang_bee_db.mdb;DefaultDir=E:\Now\(Project) RFID_r3_Homing_r1\Ben analysis;Driver={Microsoft Access Driver (*.mdb)};DriverId=25;FIL=MS Access;FILEDSN=C:\Program Files\Common Files\ODBC\Data Sources\chang_bee_db.dsn;MaxBufferSize=2048;MaxScanRows=8;PageTimeout=5;SafeTransactions=0;Threads=3;UID=admin;UserCommitSync=Yes;",
    "SELECT treatment, bee, age, days_exp_cum, trips_exp_count FROM qryTrips_days_exp", "qryTrips_days_exp", invisible);
dt4=Open Database( "DBQ=E:\Now\(Project) RFID_r3_Homing_r1\Ben analysis\Chang_bee_db.mdb;DefaultDir=E:\Now\(Project) RFID_r3_Homing_r1\Ben analysis;Driver={Microsoft Access Driver (*.mdb)};DriverId=25;FIL=MS Access;FILEDSN=C:\Program Files\Common Files\ODBC\Data Sources\chang_bee_db.dsn;MaxBufferSize=2048;MaxScanRows=8;PageTimeout=5;SafeTransactions=0;Threads=3;UID=admin;UserCommitSync=Yes;",
    "SELECT * FROM qryLeft_time_hour", "qryLeft_time_hour", invisible);
dt5=Open Database( "DBQ=E:\Now\(Project) RFID_r3_Homing_r1\Ben analysis\Chang_bee_db.mdb;DefaultDir=E:\Now\(Project) RFID_r3_Homing_r1\Ben analysis;Driver={Microsoft Access Driver (*.mdb)};DriverId=25;FIL=MS Access;FILEDSN=C:\Program Files\Common Files\ODBC\Data Sources\chang_bee_db.dsn;MaxBufferSize=2048;MaxScanRows=8;PageTimeout=5;SafeTransactions=0;Threads=3;UID=admin;UserCommitSync=Yes;",
    "SELECT * FROM qryCombo_exp", "qryCombo_exp", invisible);
pmroz
Re: script for specifying DBQ
Try this:
dbq_string = "DBQ=E:\Now\(Project) RFID_r3_Homing_r1\Ben analysis\Chang_bee_db.mdb;" ||
             "DefaultDir=E:\Now\(Project) RFID_r3_Homing_r1\Ben analysis;" ||
             "Driver={Microsoft Access Driver (*.mdb)};DriverId=25;FIL=MS Access;" ||
             "FILEDSN=C:\Program Files\Common Files\ODBC\Data Sources\chang_bee_db.dsn;" ||
             "MaxBufferSize=2048;MaxScanRows=8;PageTimeout=5;SafeTransactions=0;Threads=3;UID=admin;UserCommitSync=Yes;";
dt1=Open Database(dbq_string,
dt2=open database(dbq_string,
dt3=Open Database(dbq_string,
dt4=Open Database(dbq_string,
dt5=Open Database(dbq_string,
pmroz
Try this:
