shahin
script for saving residuals from fit model
I'm very new to JMP and have just started learning to script in order to analyze my data. I have tried to find an answer to this question in the scripting guide, but haven't found it.
Here is a script I saved. I would like to know where to insert the command "Save residuals" so that the residuals from the regression show up in the data table. I did it for principal components, but for this I just can't get it !
Fit Model(
Y( :JL ),
Effects( :TBL ),
Personality( Standard Least Squares ),
Emphasis( Minimal Report ),
Run Model(
:JL << {Plot Actual by Predicted( 0 ), Plot Regression( 1 ),
Plot Residual by Predicted( 0 ), Plot Effect Leverage( 0 )}
Thanks !
mpb
Super User mpb
Re: script for saving residuals from fit model
This should do it:
Fit Model(
	Y( :JL ),
	Effects( :TBL ),
	Run Model(
		:JL << {
			[i][b]residuals(1),[/b][/i]
mpb
Super User mpb
This should do it:
Fit Model(
	Y( :JL ),
	Effects( :TBL ),
	Run Model(
		:JL << {
shahin
Thanks so much! it seems inconsistent to have to write "save" for pc but not residuals ... but it worked :)
rickeychen
Hi, cannot see your script. Could you send me a copy please? Thanks!
