alex
script editor settings
Can you set the edit script window to be bigger? (in windows i have to click and drag twice to make it bigger...once the outer window and then the inter text box...very tedious)
How do you tend to do longer edits? (...I very soon started to just copy and paste into another editor(gVim), make changes, and copy back.)
pmroz
Re: script editor settings
Are you editing the script for a journal button? That window is quite small. If you click on File > New > Script that will open up a pretty large window.
For journal scripts I don't put much JSL code in there. Instead I just use include, to point to the actual script. Makes maintenance a lot easier.
For example, my journal button has the following script:
include("T:\My Application\My Really big JSL Script.JSL");
alex
Yes! Total newbie issue I guess. Thanks, that helps a lot.
