BookmarkSubscribeRSS Feed
vinkane
Dec 23, 2013
save data table as excel xlsb
Need to save a data table (4.5M rows) as an Excel file xlsb format. I see no error message in the log file and I see no file saved in Excel
Thanks
Jeff_Perkinson
Community Manager
Jun 23, 2011
Re: save data table as excel xlsb
Unfortunately, JMP can't write the XLSB format. It's a binary format that Microsoft doesn't document well.
Sorry.
-Jeff
-Jeff
Georg
Sep 5, 2017
Dear Jeff and all,
I'm missing capability of JMP to read xlsb files, many colleagues of mine are using this format.
Is it still true, that JMP does not support reading and writing of xlsb (because there is no documentation)?
Thanks and best regards,
   Georg
PS: using JMP 14.0.0 @Windows10 Enterprise both 64 bit versions
lwx228
Regular Contributor
Aug 14, 2018
I also use XLSB a lot, save, open quickly, and can store VBA.
It is easy to convert XLSX into XLSB using VBA batch.
Jun 22, 2012
@lwx228
I have a suggestion.  It sure would be nice if you or some other VBA user to develop a JMP Addin that probably uses the "Run Program()" function in JSL to take an XLSX and converts it into an XSLB.  And then to add the JMP Addin to the JMP File Exchange.
