AT
AT
Level V
save a presentation with variable name
I like to save the powerpoint presentation and use varaible name in the following format:
dt << Save Presentation(A_B);
A and B are variable name. I tried (A||"_"||B) but did not work. Can you help? Thanks.
cwillden
Re: save a presentation with variable name
You're trying to save a JMP table as a PowerPoint?  I'm not sure Save Presentation is a valid message for JMP data tables.  It is intended work with report windows to save the graphs and tables in the report to a PowerPoint.  See the Scripting Index for details.
However, if you really want to do that, you can get the data table as a report object and then use Save Presentation.  If you only have 1 column selected, it will just print that column to the presentation:
:A_B << Set Selected(1);
rpt = dt << Get As Report;
rpt << Save Presentation("$TEMP/Table.pptx");
Open("$TEMP/Table.pptx");
-- Cameron Willden
AT
AT
Level V
Thanks. I have already created a journal by
dt << Journal;
and then dt << Save Presentation("name");  where name is A_B
