dadawasozo
replace Y axis with heatmap plot in profiler - jmp pro 14
I wonder if this is possible added or currently available in JMP 14 pro?
1) hide y axis in profiler
2) has option to replace y-axis with heatmap plot.
The reason behind is I want to use the profiler for communication with different customers but the Y-axis value can be confidential. How can I show impact of different variables while not showing the quantitative values of Y-axis?
Re: replace Y axis with heatmap plot in profiler - jmp pro 14
Maybe change the column name used in the Y role and change its function to produce some normalized response (transformed scale)?
