jasongao
rearrange table by script
I am new to the script.
I have a table like this:
Last nameFrist nameItemsValue
WayneBruceAge35
WayneBruceHeight180
WayneAliceAge23
WayneAliceHeight172
PakerJohnAge19
PakerPeterAge25
PakerJohnHeight185
PakerPeterHeight178
And would like to convert it to this format:
Last nameFrist nameAgeHeight
WayneBruce35180
WayneAlice23172
PakerJohn19185
PakerPeter25178
I can successfully do this by using jmp subset-> rename column name -> update (with matching column) from table menu. Could someone help for the script, if assuming the data set has uncertain number of people and uncertain number of items?
Thanks a lot!
3 ACCEPTED SOLUTIONS
Thierry_S
Re: rearrange table by script
It may not be exactly what you are looking for but have you tried the Split Table feature? It is much faster than the rather convoluted method you described.
Here is how to use it: 1) split column: Value; 2) Split by: Items; 3) Grouping: First Name; Keep All Columns
Thierry R. Sornasse
This is a simple table Split
Tables==>Split
Use Item as the Split By column,
Value as the Split Columns
and Last Name and First Name as the Group columns.
Run it interactively, and then go to the output table and edit the source entry and you will see the script to use to implement it in JSL
Jeff_Perkinson
Tables -> Split will do exactly what you're looking for.
After putting your columns in the dialog and clicking OK. You'll find a Source script in the resulting data table.
Right click on the Source script and choose Edit to see the script to reproduce the split.
-Jeff
Thierry_S
Thierry R. Sornasse
Tables==>Split
Jeff_Perkinson
-Jeff
jasongao
Thank you all!
