rjbailey
"SQL Results **.jmp" file created with every SQL query. How to turn off?
I've written a JMP script with multiple SQL queries to our database and handed the script file over to a colleague for him to use.  But when my colleague uses it, the directory holding the script file soon fills up with a series of files, "SQL Results 01.jmp", "SQL Results 02.jmp", etc., one for each query in the script.  On my computer this does not happen.  I've not been able to find a preference file to disable this behavior on my colleague's computer.
How can I turn this off?  Thanks, Jeff
pmroz
Re: "SQL Results **.jmp" file created with every SQL query. How to turn off?
Once you are finished using the results of a query, you can close the table using close(dt, nosave).  For example:
dbc = create database connection(...);
sql = "SELECT SYSDATE FROM DUAL";
dt = execute sql(dbc, sql);
// process table
wait(3);
// Done - close the table
close(dt, nosave);
close database connection(dbc);
rjbailey
Thanks, but I'm not concerned with closing the table (I already do this), instead I want to prevent the generation of *files* in the directory corresponding to each SQL query.
pmroz
I'm not sure why files are appearing - maybe that's something JMP is doing behind the scenes?  In any event when you close the datasets those files should disappear.  If not you should contact JMP's tech support.
