BookmarkSubscribe
afterword
"R_Toplevel" could not be located.
Trying to get JMP to interact with R on Windows 7, JMP10, R 3.0.1.
Running:
Get Environment Variable("R_HOME")
Yields:
"C:\Program Files\R\R-3.0.1"
But running the test code:
R Init( );
R Submit("
x <- 1:5
x
R Term( );
Results in:
The installed version of R cannot be used. The entry point "R_Toplevel" could not be located.
I didn't see this error message in any other posts.  Does anyone know how I can make the connection work or what R_Toplevel is?
Jeff_Perkinson
Re: "R_Toplevel" could not be located.
JMP 10 doesn't support R 3.0.
From www.jmp.com/system:
Other Compatible Software (not required):
  • SAS 9.1.3 SP4
  • SAS 9.2
  • SAS 9.3
  • R open-source statistical software releases 2.9.2 to 2.15.3
JMP 11 will support R 3.0.
-Jeff
-Jeff
Jeff_Perkinson
  • SAS 9.1.3 SP4
  • SAS 9.2
  • SAS 9.3
-Jeff
-Jeff
afterword
Thanks Jeff.  I'll roll it back.
