BookmarkSubscribeRSS Feed
new-jmper
Jun 23, 2011
"Quality and Process" missing under "Analyze" in JMP 10
Hello fellow JMP users,
I am playing with my recently installed JMP 10 and having trouble to locate the variability chart.  The help file suggest that it is under Analyze -> Quality and Process.  But I could not find "Quality and Process" under "Analyze" !
I tried some old script and "variability chart" is still available.  So the question is: how do I make "Quality and Proces" show up under Analyze?
Thanks,
Dong
afterword
Jun 23, 2011
Solution
Re: "Quality and Process" missing under "Analyze" in JMP 10
Having just spent some time poking around the preferences myself, I think I see what you need to do.
Go to File => Preferences =>  Menu (it's all the way at the bottom).  There should be a check-box for "Quality Engineering" that has been unchecked on your copy.
Hope that helps!
afterword
Jun 23, 2011
Solution
Hope that helps!
