daniel_harding
put a logo into a GUI
I am attempting to put a company logo into a GUI. So far I have experimented with converting a jpeg into hex code and using a picture box function, but this has been a bit of a dead end. If anyone has experience with this or any suggestions, I would be extremely grateful!
Re: put a logo into a GUI
Hi - something like this should do it:
logo = "c:\MyLogo.png";
logobox = graph box(Frame Size(200, 100), xscale(0, 100), yscale(0, 100),
     << add image(
          open(logo),
          bounds(left(0), right(100), top(100), bottom(0)),
          transparency(1.0)
logobox[axis box(2)] << delete; // get rid of the Y axis;
logobox[axis box(1)] << delete; // get rid of the X axis;
nw = new window("My Window", logobox);
(I'd like to have pasted in a small script here, but I find I can't: half the text is missing every time I try.  Does anyone know why this would be?)
Cheers,
David
GoodMan
David,
I have the same problem to put a logo in a report. I tried your code, however it seem not work using a a png file in my c disk. Can you send me your JSL again to my email address, leanpharma@gmail.com?  I guess if i miss some word using the posted code.
Hi - I've just emailed you a copy of the script; however I've just checked the copy I originally posted and tried running it in both JMP 9 and JMP 10 with both a PNG image and a JPEG, and all seem to work.  Are you running JMP 8 by any chance?  I don't have a copy of that version on which to check it, but I suspect it probably wouldn't work before version 9.
Cheers,
David
Article Labels
