vince_faller
pulling large blobs from sql database
I'm trying to pull blob that ends up being larger than 65536 in the jmp column.  When I pull through ODBC, I only get the 65536.
Is this a limitation of JMP columns? Possibly ODBC?
Is there a way other than making n tables and foring through each one to concat to a final  list?  If blobs are in multiple columns, this seems to get unwieldy.
Any suggestions?
Vince Faller - Predictum
AlexS
Re: pulling large blobs from sql database
I appreciate this is a late response but I found setting the column To_Char in SQL helped.
Alex is the name, Power BI/ SQL /JMP is my game
