Batista
printing distribution
Hi! I would like to print the distributions of a big data that is saved at the "run script".
cwillden
Re: printing distribution
It should be as simple as going to File > Print (or press Ctrl + P) from the Distribution report window.  You can save the Distribution report to a different format first if desired.
-- Cameron Willden
Batista
Hi! Yes I could do that. But I have 3000 rows and 50 columns approximately. And the distribution of all is taking 270 pages because of so many levels.
