BookmarkSubscribeRSS Feed
xenoirita
Feb 24, 2013
print iteration output into one single matrix
How do I get the iteration output into one single matrix with format 3-columns and n-rows?  The column1 , column2 and column3 are filled with x(i), y(i), z(i) respectively.
n = 6;
x_i = J (1,n);
y_i = J (1,n);
z_i = J (1,n);
For(i = 0, i <=n , i++,
     x_i = 38 + (i*5.0);
     y_i = 45 + 3*(x_i) ;
     z_i = 80 + 10*(x_i) ;
mymatrix = [x_i , y_i,  z_i];
print (mymatrix);
ms
Jun 23, 2011
Solution
Re: print iteration output into one single matrix
This should work:
n = 6;
x_i = J( 1, n );
y_i = J( 1, n );
z_i = J( 1, n );
For( i = 1, i <= n, i++,
  x_i[i] = 38 + (i * 5.0);
  y_i[i] = 45 + 3 * (x_i)[i];
  z_i[i] = 80 + 10 * (x_i)[i];
mymatrix = Transpose( x_i |/ y_i |/ z_i );
Print( mymatrix );
ms
Jun 23, 2011
Solution
This should work:
n = 6;
x_i = J( 1, n );
y_i = J( 1, n );
z_i = J( 1, n );
Print( mymatrix );
xenoirita
Feb 24, 2013
Thanks, MS!
