BookmarkSubscribe
nac
nac
pharmaceutical stability assessment
Dear all,
I try to apply stability assessment according to ICH E10 stability guidance "5% change from initial value is a significant change"
I have 3 different strength (10, 20, 50) and each streght include 3 batch(Batch 1, Batch 2, Batch 3). Each batch have 3 stability condition (25/60, 30/65, 40/75) each condition have different timepoints.
I try to determine the percentage change of result from initial timepoint for each batch and condition is greater or lower than 5%.
and also the percentage change of results from previous timepoint for each batch and condition is greater or lower than 5%.
Is there anyone can help for this?
You can see my template at the attachment.
Re: pharmaceutical stability assessment
I am very busy at the moment but I was able to set up data columns with formulas for the assessment of the Result per your description. I do not have time to test it so please enter data and see if it works as needed.
nac
nac
Is there anyone have any idea about this?
Is there any response to the answer?
nac
nac
Thank you for your help. It is a solution for my problem.
Best Regards,
