alex
Community Trekker
pass column as variable to function for use in distribution
I'm trying to pass the column name to a function and then use it in the Distribution but it comes back with:
A command within the Distribution script was not recognized.
No data to analyze.
it's the Column( varB) line with-in the distribution.
Thanks,
Alex (on Jmp 8)
RuntheGraphs = function ({varB},
show (varB);
Distribution(
Uniform Scaling( 0 ),
Continuous Distribution(
Column( varB),
Horizontal Layout( 1 ),
Vertical( 0 ),
Count Axis( 1 ),
Show Counts( 1 ),
Outlier Box Plot( 0 )
Where( :IPRO_TPT_Completed == 1 )
)/*distribution*/
c="Cut Sheet";
RuntheGraphs(eval(c));
Message was edited by: alex
mattf
Community Trekker
Re: pass column as variable to function for use in distribution
Hi Alex:
Jump into JMP Scripting
By: Wendy Murphrey and Rosemary Lucas
https://support.sas.com/pubscat/bookdetails.jsp?catid=1&pc=61733
Provide an example:
/* Solution 9.2 */
/* Open the Fitness sample data tableNi. */
dt = Open( "$SAMPLE_DATA/Fitness.jmp" );
/* Assign the criteria to a global variable. */
selVar = "M";
yvar = "MaxPulse";
xvar = "RstPulse";
/* Build the main expression. */
bivExpr = Expr(
Bivariate(
Y( :Expr(yvar) ),
X( :Expr(xvar) ),
/* Identify the global variable by wrapping it with the Expr function. */
Where( :sex == Expr( selVar ) )
/* Resolve the global variable expression first. Then resolve the main expression. */
Eval( Eval Expr( bivExpr ) );
Adapting to you particular example:
dt = Open( "$sample_data/Big Class.jmp" );
c = "Height";
dist = Expr(Distribution(
Column( :Expr( c ) ),
Vertical( 0 ),
Fit Distribution( Normal )
Eval( Eval Expr( dist ) );
Best regards,
-Matt
alex
Community Trekker
I have the book open right now!
Can you give me the page?
(it looks like you did a put and past but it got lost in the html)
pmroz
This is a common problem I encounter in JSL. When all else fails I build an expression and then use eval(parse()) on it. Here's some working code:
style="font-size: 10pt; font-family: "Courier New"; color: black;">RuntheGraphs
style="font-size: 10pt; font-family: "Courier New"; color: navy;">=
style="font-size: 10pt; font-family: "Courier New"; color: rgb(0, 0, 221);">Function
style="font-size: 10pt; font-family: "Courier New"; color: black;">(
{varB}
style="font-size: 10pt; font-family: "Courier New"; color: navy;">,
style="">
style="font-size: 10pt; font-family: "Courier New"; color: rgb(0, 0, 221);">Show
varB )
style="font-size: 10pt; font-family: "Courier New"; color: navy;">;
style="">
dist_expr
style="font-size: 10pt; font-family: "Courier New"; color: purple;">"
style="">
Distribution(
style="">
Uniform
Scaling( 0 ),
style="">
Continuous
Distribution(
style="">
Column("
style="font-size: 10pt; font-family: "Courier New"; color: navy;">||
style="">
varB
style="">
style="font-size: 10pt; font-family: "Courier New"; color: purple;">"),
style="">
Horizontal
Layout( 1 ),
style="">
Vertical(
0 ),
style="">
Count
Axis( 1 ),
style="">
Show
Counts( 1 ),
style="">
Outlier
Box Plot( 0 )
style="">
style="">
Where(
:sex == \!"F\!" )
style="">
style="">
style="font-size: 10pt; font-family: "Courier New"; color: rgb(0, 0, 221);">eval
style="font-size: 10pt; font-family: "Courier New"; color: rgb(0, 0, 221);">parse
style="font-size: 10pt; font-family: "Courier New"; color: black;">dist_expr))
style="">
style="font-size: 10pt; font-family: "Courier New"; color: black;">)
style="font-size: 10pt; font-family: "Courier New"; color: black;">dt
style="font-size: 10pt; font-family: "Courier New"; color: rgb(0, 0, 221);">open
style="font-size: 10pt; font-family: "Courier New"; color: purple;">"$sample_data\big
class.jmp"
style="font-size: 10pt; font-family: "Courier New"; color: black;">c
style="font-size: 10pt; font-family: "Courier New"; color: purple;">"height"
style="font-size: 10pt; font-family: "Courier New"; color: black;">RuntheGraphs(
c )
mattf
Community Trekker
Second Try:
alex
Community Trekker
Thanks to both of you. That's great (if not a bit hack-ish.)
