tova
parsing a character of numbers that begins with 0 and keeping the initial zero
I want to make a vector of values that come from a column in a datatable.  Some of those values start with the number zero.  When I use the parse command it truncates the zero from the beginning of the number.  The column is defined as a character column.  The script I am using is eval(parse(column(DTI, "bar_pen")[i])));  How can I do this and keep my initial zeros?
Thanks,
Tova
Craige_Hales
Staff (Retired)
Re: parsing a character of numbers that begins with 0 and keeping the initial zero
dt = New Table( "Untitled",
    Add Rows( 3 ),
    New Column( "Bar_Pen", Character, Set Values( {"0001", "9999", "0900"} ) )
list = dt:Bar_pen << getvalues;
show(list); // {"0001", "9999", "0900"};
v = dt:Bar_Pen[3];
show(v, parse(v), char(parse(v))); // "0900", 900, "900"
You might not need to do the parse that converts the character data to code (which is just a number, most likely.) Then you don't need to eval the parsed code, then you don't need to convert the evaluated answer (a number) back to a string. If the values need cleaning up because of data entry errors, the eval/parse may seem to be working but will fail if a mischievous user puts bad code in the table.
Craige
tova
this is what worked for me in the end:
Repeat("0", 4 - length(char(eval(parse(column(DTI, "Bar_Pen")[i]))))) || char(eval(parse(column(DTI, "Bar_Pen")[i])));
Craige_Hales
Staff (Retired)
    Add Rows( 3 ),
v = dt:Bar_Pen[3];
Craige
tova
thanks, that is a much neater solution than the one i found...
