geof
parse string into different columns
I need your help to parse a string of data into table.
Attached are example of Raw_data table and the RSLT table I want to achieve.
For each EQP I may have a string with couple of (Position:Value) separated by ";" like
P:V;P:V;P:V;
Thanks for your help
Geof
pmroz
Re: parse string into different columns
This will do it.  I'm processing lists within lists using the WORDS function.
dt = New Table( "Raw_data",
    Add Rows( 6 ),     New Column( "EQP", Character( 1 ), Nominal,
        Set Values( {"A", "B", "A", "C", "A", "B"} )
    New Column( "Position : Value", Character, Nominal,
        Set Values(
            {"362:53;394:134;", "227:37;247:152;122:44;", "96:88;", "266:48;",
            "362:64;394:136;", "266:47;"}
// Create an empty results table
rslt_tbl = New Table( "Results", New Column( "EQP", Character( 1 ), Nominal ),
    New Column( "Position", Numeric, Continuous, Format( "Best", 12 ) ),
    New Column( "Value", Numeric, Continuous, Format( "Best", 12 ) )
m = 0;
for (i = 1, i <= nrows(dt), i++,
    one_eqp = dt:eqp[i];
    pos_val_list = words(column(dt, "Position : Value")[i], ";");
    for (k = 1, k <= nitems(pos_val_list), k++,
        one_pos_val_list = words(pos_val_list[k], ":");
        one_pos = num(one_pos_val_list[1]);
        one_val = num(one_pos_val_list[2]);
        m++;
        rslt_tbl << add rows(1);
        rslt_tbl:eqp[m]      = one_eqp;
        rslt_tbl:Position[m] = one_pos;
        rslt_tbl:Value[m]    = one_val;
pmroz
        Set Values(
m = 0;
        m++;
geof
It works fine !
Thanks
geof
