GregMcMahon
p values in inteaactive html
Hi there,
I'm using fit y by x and generating several mosaic plots and incorporating a local data filter in a dashboard. The p-values with no filter are displayed in the interactive html. When toggling the filter in the html, the plots change, but the p-values do not. I am using Chrome to view the html. Is this just not possible in the interactive mode (seeing how the p-values change that is)?
Thanks!
Greg
Re: p values in inteaactive html
currently the interactive html output does not recalculate the statistical functions within JMP.  JMP Public is what you need to be able to generate the stats behind a webpage output
GregMcMahon
Thanks!
