galactus3000
Community Trekker
number of LSL USL for M machines with N parameters each
Hello.
I know how to do this in JMP but cannot figure out how to efficiently script it.
Below is the report from which I can easily right-click  "Make Combined Data Table" and have a table with number of xSL exceedances for each of the M machines and N parameters.
In a JSL script, how do I achieve same thing?  Easy to do.  Impossible to script?
Jeff_Perkinson
Re: number of LSL USL for M machines with N parameters each
Right after posting above, @Justin_Chilton showed me that you can use Xpath to avoid the loop:
((Report( pc[1] ) << Top Parent) << XPath( "//NumberColBox[NumberColBoxHeader/text() = 'Observed Count']" ) ) << Hide( 0 );
-Jeff
8 REPLIES 8
galactus3000
Community Trekker
What's a bit frustrating is a simple "Make into Data Table" right-click provides a table replete with "Source" script.
When I right-click "Make Combined Data Table" there is no concomitant source script!
THANKS IN ADVANCE FOR ANY INSIGHT YOU CAN PROVIDE
Jeff_Perkinson
JMP 14 makes this pretty easy to figure out. The first rule of scripting is to let JMP write it for you. With JMP 14, when you right click and "Make Into Data Table" the resulting table has a "Make Into Data Table" script that will show you how to script it.
You'll need to work a bit to get the By () statement into the platform call and then direct the "Make Combined Data Table" to the outline box in the first report. Let us know if this points you in the right direction or if you need more clarification.
-Jeff
Jeff_Perkinson
Looks like our messages may have crossed. You've already seen that you can get a script to help guide you to the right outline box.
Now you need to deal with the result of a By() option in the platform launch.
Consider this script:
dt=open("$SAMPLE_DATA\Semiconductor Capability.jmp");
pc=Process Capability(
	Process Variables( :NPN1, :PNP1, :PNP2, :NPN2, :PNP3, :IVP1, :PNP4, :NPN3 ),
	By(:lot_id),
	Individual Detail Reports( 1 ),
	Goal Plot( 1 ),
	Capability Index Plot( 1 ),
	Process Performance Plot( 0 )
After running this pc has a list of platform references, one for each by group.
pc = {Process Capability[], Process Capability[], Process Capability[], Process Capability[], Process Capability[], Process Capability[], Process Capability[], Process Capability[], Process Capability[], Process Capability[], Process Capability[], Process Capability[], Process Capability[]};
So, you'll need to index into this list to get to the first report and then the proper outline box. You can use the wildcard character "?" in the Outline Box names to match an outline box without having to know which by group or parameter name it's referring to. Finally, change "Make Into Data Table" to "Make Combined Data Table".
Report( pc[1] )[Outline Box( "Process Capability ?" )][
Outline Box( "Individual Detail Reports" )][Outline Box( "? Capability" )][
Outline Box( "Nonconformance" )][Table Box( 1 )] << Make Combined Data Table;
-Jeff
galactus3000
Community Trekker
Aha .... the wildcard character ... makes sense.  trying now ...
galactus3000
Community Trekker
I'm 90% there ...
I can do the Make Combined Data Table!
Now the remaining 10% ...  I just need to do a SendToByGroup Dispatch to all to show Observed Count of Noncoformance for all my variables in all tables.
tried this and it didn't work?
Dispatch(
                {"Process Capability ?", "Individual Detail Reports",
                "? Capability", "Nonconformance"},
                "Observed Count",
                NumberColBox,
                {Visibility( "Visible" )}
//OR THIS
SendToByGroup(
        {:table == "?"},
            Dispatch(
                "Observed Count",
                NumberColBox,
galactus3000
Community Trekker
Then since this worked,
Report( pc[1] )[Outline Box( "Process Capability ?" )][Outline Box( "Individual Detail Reports" )][Outline Box( "? Capability" )][Outline Box( "Nonconformance" )][Table Box( 1 )] << Make Combined Data Table;
I tried this
Show Column( "Observed Counts" );
which did not work ...
Jeff_Perkinson
The message for displaying a hidden column is Hide(0) and the message goes to the ColBox not the table box:
Outline Box( "? Capability" )][Outline Box( "Nonconformance" )][Table Box( 1 )][NumberColBox("Observed Count")]<<hide(0);
Unfortunately, there's no way to send that message to all the boxes in the report at once. You'll have to construct a loop to find all of them and turn them on.
-Jeff
Jeff_Perkinson
-Jeff
