Geo42
non-parametric correlation matrix
Does anyone know how to create a non-parametric correlation matrix, such as what is displayed by default in the Multivariate analysis?  That matrix uses Pearson product-moment but I would like to use Spearman or Kendall but displayed in the same m x n format.  Scripting would also be fine.  Thanks.
Re: non-parametric correlation matrix
It looks like a script will be needed. But I think you have a good idea. Please look to see if it is in the JMP Wish List, and if not, add it.
Dan Obermiller
Geo42
I don't see it in the JMP Wish List.  I will add it.  Thanks for the reply and suggestion.
