lauherrera4
nominal factors
How is coding, when I have a nominal factor with 4 levels, and I need this, to get the predicted value
Jeff_Perkinson
Re: nominal factors
I think the Factor Models section of the JMP Documentation will help explain it to you.
Post back here if you have further questions.
-Jeff
-Jeff
