galactus3000
Nov 9, 2016
moving column named via string variable to after another column also named via string variable
How do I  move a column referenced by a string variable to after another column also referenced by a string variable in table st
zzz = Column(cnm);
colst = {zzz};
Eval(Eval Expr(Expr(st<<MoveSelectedColumns(colst, After(yyy)))));
my Locals show that
Variable cnm has the Value "ppg 1000" of type String
Variable yyy has the Value Column("lxt 1000") of type Column
Variable zzz has the Value Column("ppg 1000") of type Column
Variable colst has the Value {zzz} of type List
Thought I would need to use Eval, Eval Expr, Expr, etc to get this to work, but cannot seem to get it right.
Please help.  Thanks in advance.
Cheers
Galactus3000
pmroz
Jun 23, 2011
Solution
Re: moving column named via string variable to after another column also named via string variable
Here's another way that builds a string dynamically and then executes it via eval(parse()).
st = New Table( "Untitled", Add Rows( 2 ),
	New Column( "lxt 1000", Character, "Nominal", Set Values( {"a", "b"} ) ),
	New Column( "Column 2", Numeric, "Continuous", Format( "Best", 12 ),
		Set Values( [1, 2] )
	New Column( "ppg 1000", Numeric, "Continuous", Format( "Best", 12 ),
		Set Values( [3, 4] )
wait(2);
cnm = "ppg 1000";
yyy = "lxt 1000";
move_expr = evalinsert("\[st << Move Selected Columns({"^cnm^"}, After("^yyy^"))]\");
eval(parse(move_expr));
ian_jmp
Jun 23, 2011
Here's one way:
NamesDefaultToHere(1);
dt = NewTable("MoveColumns");
dt << addMultipleColumns("Column ", 10, AfterLast, Numeric);
Wait(2);
cols = dt << getColumnNames("String");
RemoveFrom(cols, 8, 3);
afterCol = "Column 08";
moveCMD = Expr(dt << moveSelectedColumns(colsTBD, After(afterColTBD)));
SubstituteInto(moveCMD, Expr(colsTBD), cols, Expr(afterColTBD), afterCol);
moveCMD
pmroz
Jun 23, 2011
Solution
wait(2);
cnm = "ppg 1000";
yyy = "lxt 1000";
vince_faller
Mar 17, 2015
only do the expr around the colst.  if you're doing an evalExpr() around a whole expr(), you're effectively doing nothing.
Eval(EvalExpr(dt << MoveSelectedColumns(Expr(colst), After(yyy))))
it's probably a good idea to do:
colst = Evallist({zzz});
unless you're trying to have colst be a list of references instead of a list of columns
