Sburel
merging the string output from several variables
Happy memorial day!
I've been struggling to merge the output from several variables.
using the show() function
In the log, the first variable is shown as d={"test_article"}
the second vari="PBS"
Afterward, I'm trying the concatenate those variables
resp_type=concat items(d,"vs",vari).
For some reasons the variable d gets ignored and I endup with " vs PBS" instead of "test_article vs PBS".
Any suggestions would be greatly appreciated.
Best,
Sebastien
Re: merging the string output from several variables
The issue is that variable "d" is not a string variable, it is a list.  And the list contains one element, which happens to be a string.
You need to read the sections in the Scripting Guide on the language structures in JSL.
     Help==>JMP Documentation Library...……….Scripting Guide
The following change should allow you to do the concatenation you want
resp_type=concat items(d[1],"vs",vari)
Sburel
Thanks a lot for the feedback.
It worked with one minor modification
resp_type=concat (d[1], " vs ", vari)
Best
