BookmarkSubscribe
newbie_alex
Community Trekker
making a join more based on a list of common vars
I would like to replace the hard coded column names in this example:
dt = dt1 << Join(
	With( dt_ref ),
	Select(
		:result_Rx_RSSI_,
		:result_snr_Rx_RSSI_,
		:type_,
		:rat_,
		:trx_,
	SelectWith( :result_Rx_RSSI_ref, :result_snr_Rx_RSSI_ref, ),
	By Matching Columns(
		:type_ = :type_,
		:rat_ = :rat_,
		:trx_ = :trx_,
	Drop multiples( 0, 0 ),
	Include Nonmatches( 0, 0 ),
	Preserve main table order( 1 ),
	Output Table( "merged_results" )
with something that starts with
common_vars = {"type_", "rat_", "trx};
dt1_only_vars = {"result_Rx_RSSI_", "result_snr_Rx_RSSI_"};
dt_ref_only_vars = {"result_Rx_RSSI_ref", "result_snr_Rx_RSSI_ref"};
... and this should lead to the same result.
How do I do that?
Thank you for your help!
newbie_alex
Community Trekker
Re: making a join more based on a list of common vars
Thank you for the feedback.
This is how I solved it thanks to this blog entry:
http://www.pega-analytics.co.uk/blog/handling-lists-of-columns/
common_vars = {"type_", "rat_", "trx"};
col_names = dt1_only_vars || common_vars;
match_str = "";
For( i = 1, i <= N Items( common_vars ), i++,
	match_col_name = common_vars[i];
	mstr = Eval Insert( ":^match_col_name^ = :^match_col_name^," );
	match_str = match_str || mstr;
// this is UGLY but I do not know any other way (yet?)
dt_str = Eval Insert(
	"dt = dt1 << Join(
	With( dt_ref ),
	Select(
		Eval( col_names )
	SelectWith( Eval(dt_ref_only_vars) ),
		^match_str^
	Output Table( \!"merged_results\!" ));"
Eval( Parse( dt_str ) );
Kevin_Anderson
Community Trekker
Hi, Alex!
There are many ways to do that.
Can you post some (anonymized, if necessary,) dt1 and dt_ref datasets?
newbie_alex
Community Trekker
dt = Open( "$SAMPLE_DATA/Decathlon.jmp" );
dt_no_score = dt << Subset(
	Output Table( "Decathlon_no_score" ),
	All rows,
	columns(
		:Name,
		:Country,
		:Name( "100m" ),
		:Long Jump,
		:Shot Put,
		:High Jump,
		:Name( "400m" ),
		:Name( "100m hurdles" ),
		:Discus,
		:Pole Vault,
		:Javelin,
		:Name( "1500m" )
dt_no_country = dt << Subset(
	Output Table( "Decathlon_no_country" ),
	All rows,
	columns(
		:Name,
		:Score,
		:Name( "100m" ),
		:Long Jump,
		:Shot Put,
		:High Jump,
		:Name( "400m" ),
		:Discus,
		:Pole Vault,
		:Javelin,
		:Name( "1500m" )
dt_recombined = dt_no_country << Join(
	With( dt_no_score ),
	Select(
		:Name,
		:Score,
		:Name( "100m" ),
		:Long Jump,
		:Shot Put,
		:High Jump,
		:Name( "400m" ),
		:Discus,
		:Pole Vault,
		:Javelin,
		:Name( "1500m" )
	SelectWith( :Country ),
		:Name = :Name,
		:Name( "100m" ) = :Name( "100m" ),
		:Long Jump = :Long Jump,
		:Shot Put = :Shot Put,
		:High Jump = :High Jump,
		:Name( "400m" ) = :Name( "400m" ),
		:Name( "100m hurdles" ) = :Name( "100m hurdles" ),
		:Discus = :Discus,
		:Pole Vault = :Pole Vault,
		:Javelin = :Javelin,
		:Name( "1500m" ) = :Name( "1500m" )
Kevin_Anderson
Community Trekker
Hi, Alex!
First, thank you for making your example much more difficult to type than your original question!  :)
I'm unclear on why you wish to use a list of common variables for a join.  Do the variables change?  Would User Dialogs be useful?  Your reasons may influence the direction you should take.
Nonetheless, let's consider that someone will have to maintain the "reference values" in your No Score dataset, and it would be helpful to record where No Country dataset values have no No Score values...that would indicate a Left Outer Join would be appropriate.
dt_recombined = Query(
	Table( dt_no_country, "t1" ),
	Table( dt_no_score, "t2" ),
  "SELECT t1.Name AS [Name from Table1], t1.Score, t1.[100m], t1.[Long Jump], t1.[Shot Put], t1.[High Jump], t1.[400m], t1.[100m hurdles], t1.Discus, t1.[Pole Vault], t1.Javelin, t1.[1500m],
    t2.Name AS [Name from Table2], t2.Country
   FROM t1
	LEFT OUTER JOIN t2
	ON  ( t1.Name = t2.Name and
			t1.[100m] = t2.[100m] and
			t1.[Long Jump] = t2.[Long Jump] and
			t1.[Shot Put] = t2.[Shot Put] and
			t1.[High Jump] = t2.[High Jump] and
			t1.[400m] = t2.[400m] and
			t1.[100m hurdles] = t2.[100m hurdles] and
			t1.Discus = t2.Discus and
			t1.[Pole Vault] = t2.[Pole Vault] and
			t1.Javelin = t2.Javelin and
			t1.[1500m] = t2.[1500m]  ) " );
If you really need, you can easily turn the variables into expressions you can evaluate and substitute at will.
newbie_alex
Community Trekker
match_str = "";
	"dt = dt1 << Join(
	With( dt_ref ),
	Select(
		Eval( col_names )
		^match_str^
ian_jmp
Perhaps I have oversimplified your case but, FYI, this also works:
dt1 = NewTable("One",
		NewColumn("A", Values([1,2])),
		NewColumn("B", Values([3,4])),
		NewColumn("K1", Values([5,6])),
		NewColumn("K2", Values([7,8]))
dt2 = NewTable("Two",
		NewColumn("C", Values([9,10])),
		NewColumn("D", Values([11,12])),
		NewColumn("K2", Values([5,6])),
		NewColumn("K1", Values([7,8]))
dt1KeyCols = {"K1", "K2"};
dt2KeyCols = {"K2", "K1"};
dtFinal = dt1 << Join(
					With(dt2),
					By Matching Columns( dt1KeyCols = dt2KeyCols ),
					Output Table( "Joined" )
newbie_alex
Community Trekker
Thank you! This is much easier to read than my approach.
