BookmarkSubscribeRSS Feed
making a combined table using a script
I wrote a script to do an ANOVA on several variables, each as a function of three factors. The platform is Fit Model using a standard OLS. I'm using JMP 9 on a Vista computer. I'm particularly interested in the connecting letter displays in the resulting report. Since there are several ANOVAs, there are as many connecting letter displays. If I right click on any one of them, I have the option to create a combined data table. This is perfect for my problem. However, I can't find a scripting command to do this as part of a script. How can I change any display table in a report to a combined data table in a script?
Thanks,
Walt
mpb
Jun 23, 2011
Re: making a combined table using a script
If you search the forum for the string "make combined data table" (without the quotes) you may find some of the results helpful.
Michael
For what it's worth, you may well end up doing something like the following, which is the sort of process I go through when I'm trying to extract one specific type of output from a platform which can supply far more than I actually need. In the following example, I'm trying to extract three tables of connecting letter displays from the Fit Model platform when analysing exactly three response variables called "Overall Liking", "Taste Liking" and "Appearance Liking", which are three different columns in a data table which has already been loaded into JMP:
style="font-size: 9pt; font-family: "Courier New"; color: black;">
style="font-size: 9pt; font-family: "Courier New"; color: green;">//
*** Start of Program ***;
Load your data file and assign
it a table ID;
style="font-size: 9pt; font-family: "Courier New"; color: black;">dt
style="font-size: 9pt; font-family: "Courier New"; color: navy;">=
style="font-size: 9pt; font-family: "Courier New"; color: rgb(0, 0, 221);">data
table
style="font-size: 9pt; font-family: "Courier New"; color: black;">(
style="font-size: 9pt; font-family: "Courier New"; color: purple;">"Consumer
Data"
style="font-size: 9pt; font-family: "Courier New"; color: black;">)
style="font-size: 9pt; font-family: "Courier New"; color: navy;">;
style="font-size: 9pt; font-family: "Courier New"; color: green;">/*
style="">
Fit
the model interactively until you've got the output you actually want,
and then
style="">
copy
the resulting script, which might end up looking something like the
following;
style="font-size: 9pt; font-family: "Courier New"; color: green;">*/
style="font-size: 9pt; font-family: "Courier New"; color: black;">dtm
dt
style="font-size: 9pt; font-family: "Courier New"; color: navy;"><<
Fit Model(
style="">
Y(
style="font-size: 9pt; font-family: "Courier New"; color: navy;">:
style="font-size: 9pt; font-family: "Courier New"; color: black;">Overall
Liking
style="font-size: 9pt; font-family: "Courier New"; color: navy;">,
style="font-size: 9pt; font-family: "Courier New"; color: black;">Taste
Liking
style="font-size: 9pt; font-family: "Courier New"; color: black;">Appearance
Liking
style="">
Effects(
style="font-size: 9pt; font-family: "Courier New"; color: rgb(0, 0, 221);">Product
style="font-size: 9pt; font-family: "Courier New"; color: black;">Consumer
ID )
style="">
Personality(
Standard Least Squares )
style="">
Emphasis(
Minimal Report )
style="">
Run
Model(
style="">
Liking
{Lack
of
Fit(
style="font-size: 9pt; font-family: "Courier New"; color: teal;">0
Plot Actual by Predicted(
style="">
Plot
Regression(
Plot Residual by Predicted(
style="">
Plot
Effect Leverage(
style="">
LSMeans
Student's t(
style="font-size: 9pt; font-family: "Courier New"; color: teal;">0.05
Crosstab Report(
style="">
Liking
{Lack
of
Fit(
style="">
Plot
Plot Regression(
style="">
Plot
Plot Effect Leverage(
style="">
LSMeans
Student's t(
Crosstab Report(
style="">
Liking
{Lack
of
Fit(
style="">
Plot
Plot Regression(
style="">
Plot
style="">
LSMeans
Student's t(
Crosstab Report(
style="">
style="">
Dispatch(
style="">
style="font-size: 9pt; font-family: "Courier New"; color: purple;">"Response
Overall Liking"
style="font-size: 9pt; font-family: "Courier New"; color: black;">}
style="">
style="font-size: 9pt; font-family: "Courier New"; color: purple;">"Effect
Details"
style="">
style="font-size: 9pt; font-family: "Courier New"; color: rgb(0, 0, 221);">OutlineBox
style="">
style="font-size: 9pt; font-family: "Courier New"; color: rgb(0, 0, 221);">Close
style="">
style="">
Dispatch(
style="">
Taste Liking"
style="">
Details"
style="">
style="">
style="">
style="">
Dispatch(
style="">
Appearance Liking"
style="">
Details"
style="">
style="">
style="">
style="">
style="">
style="">
Then
AFTER you've run it interactively and duplicated the analysis
style="">
with
the resulting script, display the tree structure of the
style="">
result
to find out whereabouts the output you want actually IS.
style="font-size: 9pt; font-family: "Courier New"; color: black;">dtr
dtm
style="font-size: 9pt; font-family: "Courier New"; color: rgb(0, 0, 221);">report
style="font-size: 9pt; font-family: "Courier New"; color: black;">dtt
dtr
show tree
structure
style="">
When
you've done that, just extract the bits you need and close everything
else.
style="">
In
this instance, the letter tables for the three response variables are
numbers
style="">
6,
13 and 20 (though obviously they'll be different for you).
style="">
I'm
therefore
style="">
making
data tables out of those three Table Boxes in the tree structure.
style="font-size: 9pt; font-family: "Courier New"; color: black;">letters1
dtr[
style="font-size: 9pt; font-family: "Courier New"; color: rgb(0, 0, 221);">tablebox
style="font-size: 9pt; font-family: "Courier New"; color: teal;">6
style="font-size: 9pt; font-family: "Courier New"; color: black;">)]
style="">
style="font-size: 9pt; font-family: "Courier New"; color: black;">letters2
dtr[
style="font-size: 9pt; font-family: "Courier New"; color: teal;">13
make combined
data table
style="font-size: 9pt; font-family: "Courier New"; color: black;">letters3
dtr[
style="font-size: 9pt; font-family: "Courier New"; color: teal;">20
make combined
data table
style="font-size: 9pt; font-family: "Courier New"; color: rgb(0, 0, 221);">window
style="font-size: 9pt; font-family: "Courier New"; color: purple;">"Show
Tree
Structure"
close window
style="font-size: 9pt; font-family: "Courier New"; color: purple;">"Fit
Model"
close window
close window
style="font-size: 9pt; line-height: 115%; font-family: "Courier New"; color: green;">//
*** End of Program ***;
Sorry - I forgot to mention: to capture the script that is generated by running the Fit Model platform from the main menu, just click on the red arrow next to the "Least Squares Fit" bar at the top of the output window, and from the resulting drop-down menu select Script | Save Script to Script Window. You can then tinker with the script to make any changes you need before simply copying it into the window in which you're developing your own version of it. For example, you'd probably eventually want to modify it so that the number and names of the columns to be analysed and/or the main effects to be incorporated into the ANOVA are entered from a menu by the user, as opposed to being effectively hard-coded.
