FilipBauwens
make correlation from 1 parameter to several parameters
I have 1 measured parameter in function of several fixed parameters.
How can I detect a correlation?
Re: make correlation from 1 parameter to several parameters
Your question begs for more detail.  A descripting of the "fixed parameters" would be helpful.
You may want to look into the Generalized Regression Personality in the Fit Model platform.
