BookmarkSubscribeRSS Feed
logistic regression on variable with values between 0 and 1
SAS allows you to do a logistic regression on a variable that has values bewteen zero and one (not integers)...is there a way to do this in JMP?
Re: logistic regression on variable with values between 0 and 1
Chap 9 of JMP Stat and Graph Guide talks about simple logistic regression. Might be helpful.
