lockup columns
gianpaolo_polsi
Mar 23, 2016
Good morning,
starting from a discussion of a couple of week ago (here) , i have added to the solved script a simple GUI in order to select  the columns to be analyzed and  the % of stagnant or empty elements in such columns.
i want create a new columns to check  which columns of my table are almost empty or stagnant, but
i have a problem that i'm not able to lock-up the processed columns to the main table,  in my script something is wrong,
can you help me
thanks in advance
here the code:
clear globals();
// code to choose among all opened tables which one will be selected for the analysis
OpenDT = List();
For( i = 1, i <= N Table(), i++,
Insert Into( OpenDT, Data Table( i ) )
dlgDT = Dialog( "Select Data Table for analysis", VList( selectDT = List Box( OpenDT ) ), HList( Button( "OK" ), Button( "Cancel" ) ) );
Show( dlgDT );
If( dlgDT["button"] == 1,
Remove From( dlgDT, N Items( dlgDT ) );
Eval List( dlgDT );
Current Data Table( selectDT[1] );
// -----------------------------------------GUI -----------------------------------------//
cd = Column Dialog(
Title( " Columns screening " ),
List= ColList( " select Columns >> ", MinCol( 1 ) ),
HList( "% of empty column > (0-100)",
"% of stagnant columns < (0-100)", mypercent = EditNumber( 90 ) ),
//declaration of variables
percent = cd["mypercent"];
mylist = cd["List"];
dt= selectDT[1];
delcols = {};
numRows = nrows(dt);
for(i=1; maxi=Nitems(mylist), i<=maxi, i++,
if(nrows(loc(aslist(column(dt,mylist[i])<<getasmatrix),mode(column(dt,mylist[i])<<getasmatrix))) > numRows * percent/100,
insert into(delcols, i);
if(Col N Missing(column(dt,mylist[i])) > numRows * percent/100,
nitems = N Items( delcols );
colname = {};
colnamelist = {};
For( p = 1, p <= nitems, p++,
colname = Column( delcols[p] ) << Get Name;
Insert Into( colnamelist, colname(p) );
subDt1 = dt << Subset (Columns(colnamelist), Output Table Name("check removed columns"));
Gianpaolo Polsinelli
ian_jmp
Jun 23, 2011
Solution
I'm sorry, but I haven't looked at the details of your code, nor what it's trying to do. But maybe it should be:
		Insert Into( delcols, myList[i] )
rather than:
		Insert Into( delcols, i )
1 REPLY
ian_jmp
Jun 23, 2011
Solution
rather than:
