Hi all,
I would like to launch a PL/SQL (stored in Oracle database) procedure into JMP 14
Through menu File -> Database -> OpenTable and in Advanced button, I select the procedure and give all parameters in the SQL window but when I clic on Execute SQL button, it fails.
Below the SQL construct automaticaly by JMP
CALL "domain"."my_oracle_pro" output()
Thanks for your help
Try running it in JSL. JMP can not handle OUT parameters from PL/SQL btw. Here's a simple example showing how to do this in JSL; you'll need to supply some of the parameters as indicated.
// Create an ODBC connection to your Oracle database. Replace <tns_name> with your TNS entry for the
// database in question, <username> and <password> with the proper credentials for your database
// Also make sure the driver has the correct name.
dbc = create database connection("Driver={Oracle in OraClient11g64_home1};Dbq=<tns_name>;UID=<username>;PWD=<password>;");
// Put values in for parameters to PL/SQL procedure call
param1 = "foo";
param2 = "bar";
sql_statement = evalinsert("begin myschema.myprocedure('^param1^', '^param2^')");
show(sql_statement);
execute sql(sql_statement);
close database connection(dbc);
param1 = "foo";
param2 = "bar";
