galactus3000
jsl script to save nonpar density quantile on local data filtered bivariate ... please help
Running script where there's a local data filtered nonparametric density in Bivariate platform and want to save the nonparametric density quantiles but unable to.  The script when run saves density quantiles, but not for only the filtered rows like it does when I run in non-script mode.
 here is what I am trying
obj=Bivariate(
	Y( :mapx ),
	X( :mapy ),
	Automatic Recalc( 1 ),
	Nonpar Density( {Color Theme( "Spectral" )},{Save Density Quantile} ),
	Local Data Filter(
		Add Filter(
			columns( :Label ),
			Where(
				:Label == {"type1", "type3", "type7", "type20"
			Display( :Label, Size( 181, 102 ), List Display )
but again the nonpar density quantile is saved for all rows rather than just filtered rows.
Please help.
Thanks in advance
Re: jsl script to save nonpar density quantile on local data filtered bivariate ... please help
Current Data Table() << Data Filter(
	Location( {88, 88} ),
	Mode( Show( 1 ), Include( 1 ) ),
	Add Filter(
		columns( :Label ),
		Where( :Label == {"type1", "type3", "type7", "type20"} ),
obj=Bivariate(
	Y( :mapx ),
	X( :mapy ),
If you use a Global Data Filter, you will get what you want.
galactus3000
how would that work in jsl script?
	Add Filter(
		columns( :Label ),
obj=Bivariate(
	Y( :mapx ),
	X( :mapy ),
Another solution would be to issue the Save command separately from the launch:
obj = Bivariate(...);
Wait(0);
obj<<Nonpar Density({Save Density Quantile});
The Wait() is sometimes necessary with filters to ensure that the filter activates before the next command proceeds.
