jsl colorize profiler and show data in Marginal Model Plots
mkennke
Mar 18, 2016
can anybody tell me how to activate the "Colorize Profiler" (Variable Importance) and "Show Data" (Marginal Model Plot) function with JSL?
Following a test script where i can activate the coloration and the data by hand but not via JSL.
dt = Open( "$SAMPLE_DATA/Tiretread.jmp" );
Profiler(
	Y( :Pred Formula ABRASION, :Pred Formula MODULUS, :Pred Formula ELONG, :Pred Formula HARDNESS ),
	Expand,
	Dependent Resampled Inputs( 1 ),
	Link Profilers( 1 )
ian_jmp
Jun 23, 2011
Solution
I'm sure there is a direct way to do this, but I can't recall the syntax at the moment. So here's an indirect way (the 'Wait' statements are for cosmetic effect, of course):
// Open Tire Tread
// Use Profiler with predictions
pr = dt << Profiler(Y( :Pred Formula ABRASION, :Pred Formula MODULUS, :Pred Formula ELONG, :Pred Formula HARDNESS ),);
// Assess variable importance
Wait(2);
pr << Dependent Resampled Inputs( 1 );
// Get the 'little red triangle' for Variable Importance
Wait(2);
lrt = Report(pr)[OutlineBox(3)] << getScriptableObject;
lrt << Colorize Profiler;
// Get the 'little red triangle' for Marginal Plots
Wait(2);
lrt = Report(pr)[OutlineBox(10)] << getScriptableObject;
lrt << Data;
mkennke
Mar 18, 2016
Solution
Thank you! It works. But my Report is a little bit danamic (one to six Y's). Because of that i modified your script with a "For" and a "Try" function.
// Open Tire Tread
pr = dt << Profiler(Y( :Pred Formula ABRASION, :Pred Formula MODULUS, :Pred Formula HARDNESS ),);
For (i = 1, i <= 20, i++,
Try(lrt = Report(pr)[OutlineBox(i)] << getScriptableObject;
lrt << Data;))
ian_jmp
Jun 23, 2011
Solution
// Open Tire Tread
Wait(2);
Wait(2);
Wait(2);
lrt << Data;
mkennke
Mar 18, 2016
Solution
// Open Tire Tread
lrt << Data;))
