fr2007
joining two sheets and chaning the format of the resultant sheet
hi all
iam trying to join two excel sheets(i have a common column in both the sheets) using Join command in JMP. For the resultant sheet (FInal. xlsx), I need to change the format of one particular column from chanracter to numeric. I want to include this in my script so that if I run the script, I get joined excel sheet with the column format changed
ex:
Data Table( "Sheet1" )
<< Join(
With( Data Table( "Data" ) ),
By Matching Columns( :Name= :Name2),
Drop multiples( 1, 1 ),
Name( "Include non-matches" )(0, 0),
Preserve main table order( 1 ),
Output Table( "Final Sheet" )
in the final sheet, i want to change the format of the column "D" from character to numeric
pmroz
Re: joining two sheets and chaning the format of the resultant sheet
dt = data table("Final Sheet");
column(dt, "D") << data type(numeric) << analysis type(continuous);
7 REPLIES 7
kevinmc
in base sas:
data data1(rename=(name2=name)); /*here variable name2 change to name why because we need common variable while joining*/
set data;
run;
data finalsheet;
merge sheet1 data1;
by name;
dd=input(d,9.);/* by using input function we can convert character to numeric*/
run;
fr2007
i am trying to write a script in JSL..i performed the join function using the tables->join functionality and just copied the script from the script editor. Now I want to change the format of one of the columns in the resultant sheet. From Character to Numeric. How do I include this?
pmroz
fr2007
Thank you so much. I want to add a small piece of code to the resultant code..i want to take out all the rows that have the numeric value of '0' in the column D;
ex:
<< Join(
match_rows = dt << get rows where(contains(:D, "0"));
newdt = dt << subset(columns(), rows(match_rows));
but iam unable to get the rows that has the numeric value of 0 in the column D and then subtract the value of column E from Column C (which are in date format mm/dd/yyyy)..can you please help me with this code?
pmroz
Since D is now numeric you can't compare it to a string ("0").  This code will work:
match_rows = dt << get rows where( :D == 0 );
dt << delete rows(match_rows);
fr2007
but this code gives me rows that have the numeric value of 0 in column D. But it is not giving the difference between Column E and Column C (which are in date format). The difference between the two days should be displayed in another new column(along with all the columns in the "Final Sheet").
fr2007
