anneg
jmp10 excel import column 1 as header
I don't find in jmp 10 in the preferences the "use Excel labels as Heading "Always"" like in jmp9, so the problem is, that the first column in an excel spreadsheet isn't recognized as a heading.
jmp9 - preferences:
jmp10 - preferences:
also in jmp10 this doesn't do the trick (column Names are on line 1; data starts on line 2:
If I open it manually I can choose - always enforce ExcelRow1 as labels:1949_jmp10_excel_import.jpg
but it isn't saved for the next excel file and that ist frustrating, because every script with excel import doesnt work either in jmp10.
Is there any solution to this problem?
Thanks in advance.
bwanders
Re: jmp10 excel import column 1 as header
Click on JMP in the Excel toolbar, then click on  "preferences".  You will see where to check the box for "Use first rows as column names"
