ks_SES
iterate over all columns and do conditional coloring based on standard deviation
My original goal was to  color the cells in a single column based on whether the value of a certain cell is: within 1 sigma, > 1 sigma but <2 sigma, > 2 sigma but <3 sigma, and >3 sigma, the sigma is the standard deviation of the very column. Now I hope to iterate over all columns and execute the conditional coloring on all of them, but my for loop code as follows does not work.
col=dt<<get column names(string);
nc=nitems(col);
for(i=2,i<=nc,i++,
mu = Col Mean( :Name(col[i]) );
sd = Col Std Dev( :Name(col[i]) );
lo = mu - 3*sd;
hi = mu + 3*sd;
rows = dt << Get Rows Where( lo <= :Name(col[i]) <= hi );
:Name(col[i]) << Color Cells( "Red", rows );
rows = dt << Get Rows Where( :Name(col[i])< lo | :Name(col[i])> hi );
:Name(col[i]) << Color Cells( "Purple", rows );
lo = mu - 2*sd;
hi = mu + 2*sd;
:Name(col[i]) << Color Cells( "Yellow", rows );
lo = mu - sd;
hi = mu + sd;
:Name(col[i]) << Color Cells( "Green", rows );
Re: iterate over all columns and do conditional coloring based on standard deviation
I modified your script a little, by changing your references from using the :Name() function, to using the Column() and As Column() functions.  I also changed the << get column names call slightly.  But other than that, you were on the right path.  My script appears to work as you wanted
dt = Current Data Table();
col = dt << get column names( string, continuous );
nc = N Items( col );
For( i = 1, i <= nc, i++,
	mu = Col Mean( Column( col[i] ) );
	sd = Col Std Dev( Column( col[i] ) );
	lo = mu - 3 * sd;
	hi = mu + 3 * sd;
	rows = dt << Get Rows Where( lo <= as Column( col[i] ) <= hi );
	Column( col[i] ) << Color Cells( "Red", rows );
	rows = dt << Get Rows Where( as Column( col[i] ) < lo | as Column( col[i] ) > hi );
	Column( col[i] ) << Color Cells( "Purple", rows );
	lo = mu - 2 * sd;
	hi = mu + 2 * sd;
	Column( col[i] ) << Color Cells( "Yellow", rows );
	lo = mu - sd;
	hi = mu + sd;
	Column( col[i] ) << Color Cells( "Green", rows );
	lo = mu - 3 * sd;
	hi = mu + 3 * sd;
	lo = mu - 2 * sd;
	hi = mu + 2 * sd;
	lo = mu - sd;
	hi = mu + sd;
ks_SES
Thank you! It works.
