anders_bankefor
inputting data from an interactive interface
In JSL would like to create an interactive interface were a user can input values into a column. The column should be of type Continuous.
For example, the user inputs a value into a dialog box which enters the value into a column:
x = UpperLimit, y = LowerLimit
Age   Name      UpperLimit      LowerLimit
40     Peter        30                   45
Does anyone have any suggestions of how to accomplish this?
- Anders
Re: inputting data from an interactive interface
Anders,
If I am following what you want, the script below will input upper and lower limits and add them to a data table.  I have annotated the script to hopefully allow you to see what the example is doing.
// Create the new data table and it"s columns
dt = New Table( "Limits" );
dt << New Column( "UpperLimit", Numeric, Continuous );
dt << New Column( "LowerLimit", Numeric, Continuous );
// Open a display window to enter the data into
InputWindow = New Window( "Enter Input",
// Add a verticle list box to structure the position of the display
V List Box(
  // Add some space
  Spacer Box( size( 1, 10 ) ),
  // Display the instruction text
  Text Box( " Enter in the inputs" ),
  // The following displays need to be side by side
  H List Box(
   // Display text to infor the user what data to enter
   Text Box( "Enter in the Lower Limit" ),
   Spacer Box( size( 10, 1 ) ),
   // Use a number edit box to capture the users input and
   // give the display object the name "LLimit"
   LLimit = Number Edit Box( . ),
   Text Box( "Enter in the Upper Limit" ),
   // give the display object the name "ULimit"
   ULimit = Number Edit Box( . )
  // Add a couple of control buttons
  H List Box(
   // The first button box will add the values to the data table, if the
   // values are valid
   Button Box( "Add the Values",
    If( Is Missing( LLimit << get ) == 0 & Is Missing( ULimit << get ) == 0 & (ULimit << get) > (LLimit << get),
     // If the values are valid, add a row to the data table and set the values
     dt << add rows( 1 );
     dt:LowerLimit[N Rows( dt )] = LLimit << get;
     dt:UpperLimit[N Rows( dt )] = ULimit << get;
     // If the values are not valid, set them to missing and
     // display a dialog to the user
     LLimit << set( . );
     ULimit << set( . );
     Dialog( "The values entered are invalid:" );
   // This button box closes the display window
   Button Box( "Stop Adding", InputWindow << Close Window )
ian_jmp
Level X
There are many ways to do this, and a good UI design depends on exactly what information you want to surface to the user so they can reliably perform the input task. Do you want or need to show all the rows in the table, or just one at a time? Do you need to also show the existing values in one or more of the other columns?
anders_bankefor
Hi Ian and thank you for your quick answer.
well im new to JSL therefore I've not got a full grasp of the syntax yet and all my attempts of writing a code that will simply store an input from a user into a variable has therefore failed. However I do know some basics in java programming and the corresponding feature I'm looking for is a scanner class.
example in java:
Scanner sc = new Scanner (System.in);
Int Upperlimit = scanner.nextInt();
In JMP I would like it to work as following:
As far as I can imagine all te rows for both the new columns and other columns sould be visable (maybe this will change in the future).
try (
UpperLimit = scanner.nextInt
dt = Current Data Table ();
dt << New Column ("UpperLimit", Numeric, "Continuous", Values ( UpperLimit ) );
//the same should be done with LowerLimit
if (UpperLimit < LowerLimit, throw ("!Error") );
I hope you understood my examples.
BR
Anders
Anders,
V List Box(
  // Add some space
  H List Box(
  H List Box(
   // values are valid
     LLimit << set( . );
     ULimit << set( . );
anders_bankefor
Thank you a lot, this was precisely what I was looking for and more!
Cheers
-Anders
ian_jmp
Level X
If row-wise editing is OK, I wanted to also mention this:
dt << New Column( "Lower Limit", Numeric, Continuous );
dt << New Column( "Upper Limit", Numeric, Continuous );
dt << rowEditor;
This has the shortcoming that it doesn't enforce the USL > LSL requirement, but this could possibly be done by subscribing to changes to 'dt' (look for 'Subscribe' in 'Help > Scripting Index'). Also, be aware that you can add column properties to the columns in the table http://www.jmp.com/support/help/Expression_Data.shtml, which include a 'range check' on the values.
